Bob E.
Installing a charging station in a garage for the new car owner. The charger
is surface-mount.
The easiest install will be surface mount using liquid-tight flex on top of
the sheetrock.
Problem is that the load panel (nearby, on the same wall) is flush-mount with
knockouts (obviously) beneath the 'rock.
I'm considering running the flex on the surface and doing a "submarine"
trench / slit in the 'rock such that the flex will mate straight to the side
of the panel.
Any other ideas other than this?
(In USA.)
Thanks.
is surface-mount.
the sheetrock.
of the panel.
(In USA.)
Thanks.
