Mains electricity to circuit board
Hey,
I've been looking for a circuit that i can use to check if there is power through the mains electricity but dont have a clue where to start,
Basically, I want to use a microchip (programmable IC) which will detect when the mains electricity is on/off but dont have a clue where to start in terms of making a circuit and then designing it so that it doesn't blow my microchip to pieces. Preferably without any special components of any sort
Any help would be great
I would say spend a few bucks and get something like this look under shopping they range from around a dollar to over 50, the main difference is sensitivity
I paid 10 for a craftsman from Sears that does what I need it to do, youll spend more than that on parts for a circuit without a micro, plus you dont have to fool around with the mains voltage
Use an optoisolator with a capacitor to drop the voltage to the LED side of it. Be sure to also bypass the LED with a diode pointing in the opposite direction. You should see a 50/60 Hz square wave out when the lines voltage is on.
Bob
Like this:
The LED is the input of the optoisolator.
The capacitor is sized for 120V 60Hz and a 20ma LED, if different you need to resize it.
Bob
