bud-- said:
The ground is included in sizing the conduit (the OP's question)
because it takes up space.
The ground (and, in general, neutrals that carry only unbalanced
current) are not counted as current carrying conductors for
determining derating of allowed wire "ampacity".
I am sorry but the ground wire is also included in the calculations
because it too, can carry constant current in cases where protection
does not engage. Get your facts correct. The ground wire is just as
important of a conductor as any in a race way and is assumed to be able
to handle the full current load at 100% duty. If what you say is true,
which I know it isn't, we could put pissy small ground wire in the race
way, why waste copper. But that isn't the case because it isn't true.
You see, we know a lot about this subject because one of our sister
plants once got a citation for insufficient ground wire size and space
in a race way due to an accident investigation. The EMT had a short in
it but didn't trip the protection down stream. Some one got electrically
hurt, not killed but hurt. #6 AWG wires with #8 Ground wire in the pipe
with only enough clearance to account for the #6 wires and the ground
wire not being of said gauge by code. They got a fine even though it
wasn't the cause of the accident. The problem was physical damage caused
by a fork truck. Yes, the the fine also included improper guarding of
electrical areas and spacing.
The law suit put into place by the person that got injured never fully
follow through because about a mouth later, while said injured person
was suppose to be home recovering, was driving around and got side
railed and killed in an intersection accident. Of course, the person
having a alcohol problem I am sure didn't contribute to it.
Now if you want to talk about drain wires we can get on that subject too!
Btw, we manufacture high power wires and cables for a variety of
things. However, the power transmission systems in use in our facility
isn't any better then the average hack systems you see in most places.
The only good wiring that i've seen in house is what our own
electricians do for the production machines and offices. THey do follow
protocol.
Jamie
