I have a large Kenmore over the stove type microwave oven that started growling last week. We pulled it apart and found that the magnetron had a shortbetween anode and filament. The diode and cap both check good. The cap is a 1.05uf 2100V unit. I have several new magnetrons in stock meant for comparable GE over the stove units. I don't know what value of cap is used with these though. In my travels I have seen caps as low as .90uf. If the GE magis the same physical size and mounts the same as the bad Kenmore does whatwould be the harm in using it if the present 1.05uf cap in the Kenmore were a different value from what the GE calls for? Thanks for any input. Lenny
Platforms
Content
