Thanks for your elaborated and dedicated response, debe.
OK; about 110V peak unloaded.
These schematics shows that when the primary is grounded/shorted by the switch, the engine turns off, as the passing flywheel magnet 1 does not produce spark in that condition. Primary and secondary are not in parallel.
That primary kill terminal is this spade:
Now, with that kill terminal
open circuited there is no current in the primary. But the engine runs.
Is then, the magnet induction picked only by the secondary coil ? There is no transformer action from primary to secondary ?
With that kill terminal grounded, there is current in the primary when the magnet passes by. Then, if there is current, there should be transformation from primary to secondary for spark to be created. But the engine stops.
Some light, please ?
