Hi to all.
I have a simple(I think) problem that I'm hoping someone can
help me with.
I want to connect a remote transmitter / receiver pair ( garage door
opener type thing) to an alarm system magnetic switch.When the door/
window is opened it sends a signal to the receiver and activates the
relay.
Hope I'm getting the idea across.
I only have normally open switches. If the door/window is closed and
the magnet is near the reed switch it is CLOSED.
Does anyone have any idea how I can connect the xmitter to this
arrangement so that it is turned on when the switch becomes open.
It must draw no power while closed.(battery operation)
The obvious answer is use a switch that is open when near the magnet
and closed when moved away(N/O) , and connect this to the button of
the xmitter , But I don't have this type of sensor.
My initial idea was to connect the xmitter from Batt+ to gnd through
a PNP transistor(emitter) , collector to GND. The base connected to
Batt+ via mag switch and the base to GND via a resistor.The switch
keeps the pnp off until it opens and the resistor turns the transistor
on.Problem it the constant current draw via the switch and resistor.
Any clever ideas how to get this arrangement to work?
Hope I'm not being to vague in my description.
Cheers
Rob
help me with.
relay.
Cheers
Rob
