It does seem like a lot of work.. Specially to somebody that doesnt know
muhc about circuit design. I am a programmer for 16 yrs but not much of a
circuit designer..
Have you done much with MSR heads/circuits?
Yes. Ever hear of Verifone?
Finn Jorgensen's "Complete handbook of magnetic recording" is a good read,
if you can find it.
You have two options doing it in analog:
You can terminate the head with the proper impedance, and read the signal in
voltage mode, which means that the output will vary in amplitude according
to the read speed, and will require tricky filter design to help smooth the
response.
Or, you can amplify the head with a current to voltage circuit which works
nicely.
Or, buy a "decoded" reader with clock and data outputs.
At Verifone, we didn't want to pay the $12 for the readers, so we
charachterized some inexpensive far east heads, did our own amp (the first
method) and decoded the F-2F in firmware. It wasn't easy.
Later, I hit on the second approach. While you still have to decode it in
firmware, the analog part is a lot less interesting.
We also had to design proper geometry for the head mounting bracket, and
deal with the wiring coming off the back of the head dragging the head
around.
Later still, I solved all that by mounting the head direct to the PCB, and
routing away the PCB material to form a spring, cable, and mount for the
head at essentially zero cost. (patented)
If you have anything near the head that radiates a magnetic field, then
you're in for even more fun, with special steels and learning how to help
those fields go somewhere else. (assuming you can't avoid making them in the
first place, which is the far better solution)
Did I mention that I'm available for consulting or employment?
