Anthony Tomah
Hi all,
I'm a newbie to the topic of home alternative energy but it is interesting
to me none-the-less. Bear with me here as I use ignorant language.
Question # 1 concerns magnets in the motor itself. Does the strength of the
magnet help determine the energy output? Some magnets certainly have
stronger pulling power than others. The magnets in the side of a chip clip
are not as strong as the magnets I pulled out of a hard drive recently.
Question # 2 concerns generator motor rpm. The motor on my large tablesaw
requires a certain amount of watts to turn at roughly 3600rpm. Would it
produce the same amount of energy if rotated in the opposite direction at
3600 rpm?
Question # 3 concerns waterwheels. Is there a calculator on the web or a
formula that will tell me how large a waterwheel sprocket has to be to
rotate a motor connected via chain or belt at, say, 3600 rpm? And, if there
are ways to do this and produce enough power, would it be feasible to design
a waterfall with a waterwheel to generate power, which in turn, powers the
pump to feed the water AND, and this is a big AND, produce excess power?
Thanks so much.
Tony
3600 rpm?
Thanks so much.
Tony
