Thanks... I've got my solder sucker and soldering station ready... I'll
keep away from the pots. I've got an isolation transformer and o-scope.
I've used the scope on digital circuits however the voltages inside a tv set
concern me. Worried about hooking the probe to a live circuit and smoking
something... My iso is only good for 1amp anyway.
There's nothing "hot ground" on the convergence board. The
power board is another story. You may not need the scope on
this job, anyway.
I'll poke around those boards looking for questionable solder joints on the
connectors. I find it a lot on the arcade boards I tinker with. Since I
have blue deflection, I would bet it is the convergence board. The pots
also sound like a likely place to look for trouble.
Actually, I've never seen a bad pot on these boards. There's
no significant current through them, and they don't get turned
often enough to wear out the resistance element or wiper.
Found a set at
www.servicemanuals.net . The only problem is that the parts
all have some manufacturers code on them. Voltages and general information
should make it easier to find what I'm looking for.
If it's a 12-digit number, like 4835 209 67169, it's probably
the Philips part number, and there are plenty of folks on this
group who can look it up for you. I think you'll find that
the parts in the set have real-world numbers printed on them
anyway.
Thanks a bunch! TV works pretty good, I got it free by simply hauling it
off for someone. The internal battery is dead as well.
Yeah, it's old enough. Pretty standard lithium coin cell.
Not in an easy-to-replace holder, unfortunately.
Brightness is a bit low. Perhaps it is time to change the fluid.
The picture will have a "milky" look due to light diffusion
when the fluid is cloudy. Blue tube is always the worst,
likes to grow algae encrustation inside. You can tell by
looking into the tubes with the front screen off. Dusty
lenses and greasy/nicotine filmed mirror can scatter plenty
of light, too.
They weren't all that bright when new, and considering its age
the tube phosphors are probably well burnt. Don't expect it
to look as bright as a direct-view CRT. Turning things up will
accelerate the phosphor burn and shorten whatever life is left.
If you have to tweak the screen, drive, background controls,
try to do only enough to get good color tracking.
