Hi - I have a Magnavox, model 55ME314V/F7 s/n DS3A1438112657. The set will not power up, and the power board is an A4GRDMPW. This is a different board than I have see on other sites.
F602 - 1 2.5A 250V fuse appears to be blown, as well as diodes D601, D1707, and D613 (i.e. diodes read 0, vs others that read .5 or .6 on simple multimeter) . All other diodes, capacitors, and resistors give good readings.
I found diodes at Fry's, so no issue there.
I have found multiple similar fuses at littlefuse.com : TE7 - 804 series, TE5 - 392 series, TE5 - 400 series. How do I know which one is correct, or doe is not matter? (I can't seen to upload an image of the fuse ...)
Thanks!
Thanks!
