Mike
I got this magnovox that was completely dead with only a click.
found horiz output transistor shorted, and replaced. noticed the set had the
vertical output IC replaced at one point along with its associated diode and
resistor.
after replacing the horizontal output transistor, the set now powers on
momentarily with a good picture, but goes into shutdown 5 to 10 seconds
later. then the set powers back on automatically, and the cycle keeps
repeating like clock work.
Ruled out the CRT by removing neck board, and ruled out an overload via vert
IC by cutting its supply. same issues, found bad solder around the
horizontal drive transformer and resoldered this and other nearby components
to no avail.
I dont think its the flyback, or i wouldnt have any HV or picture at all.
Only thing left is electrolytics in the power supply and possibly the yoke.
Any ideas? Thanks...
resistor.
to no avail.
