Marco Trapanese
Take an LVDT (series-opposite), apply a sine wave on the primary coil
and measure the output signal on the secondary coil with an oscilloscope.
Do you agree you *must* see a change in the amplitude when you move the rod?
At least you should expect a null signal when the rod is place at null
point.
What if this doesn't happen? I mean the output signal changes very
slightly around it's maximum.
Double checked the connections, changed the LVDT with new ones - no chance.
What else?
Marco
point.
What else?
Marco
