Ramon Crichlow
Thanks to Linear Technologies for making available such easy to use
and powerful freeware. However I am having the following problem
modeling a crystal:
Using matlab I plotted the impedance of the crystal vs. frequency.
When I simulate with LTSpice using the exact same values I get a
different response. I have used the alternate solver, set the time
step very small (1000 steps per period), and played with the tolerance
settings, all to no avail.
These were the parameters I was using for the crystal:
Rseries = 100 OHM Lseries=2.2e-6 H Cseries=0.2181756e-14 F
Cparallel=3e-12 F
This crystal was placed in parallel with a sine voltage source with
frequency 72.647000 MHZ and 1mV (peak to peak)
The magnitude of the current through the crystal in transient analysis
given by LTspice to be 2.1e-6 A (peak to peak)
The correct value for should be 8.2e-6 A (peak to peak)
Anybody have any ideas? (My guess is roundoff error)
modeling a crystal:
Cparallel=3e-12 F
