stef said:
I would want to use the AD633(multiplier) in LTspice as a graphic component
(like the other component included in ltspice) i downloaded the file .cir
but i don't know how to tranform it to create a component which could be use
with the graphic interface.
Thanks for your help.
Hello Stephane,
there is a good description about symbols in the LTSPICE-YAHOO group.
http://groups.yahoo.com/group/LTspice
This documentation is in the download area under
files/Tut/Symbol Types For Subcircuits .
Anyway, I will give you a qick start especially for the AD633 here too.
The pin order of the model is by chance exactly the order of the
physical pin numbers of the DIP-8 symbol.
So simply add the generic DIP-8 to your schematic. It is in the
"Misc" directory where you pick components(symbols).
Then move your mouse pointer over the symbol and click the right button
of your mouse. A window pops up. Enter in the field "SpiceModel"
the value AD633.
Put the model file "AD633.cir" into your schematic directory or into
the the LTSPICE installation subdirectory ....\Lib\sub.
Add the command line .include AD633.cir to your schematic.
You can make a much nicer looking symbol after you have read the
mentioned documentation and/or the help pages of LTSPICE.
The symbol editor is included in LTSPICE.
Best Regards
Helmut
* AD633 Analog Multiplier Macro Model 12/93, Rev. A
* AAG/PMI
* Copyright 1993 by Analog Devices, Inc.
* Refer to "README.DOC" file for License Statement. Use of this model
* indicates your acceptance with the terms and provisions in the License
Statement.
* Node assignments
* X1
* | X2
* | | Y1
* | | | Y2
* | | | | VNEG
* | | | | | Z
* | | | | | | W
* | | | | | | | VPOS
..SUBCKT AD633 1 2 3 4 5 6 7 8
EREF 100 0 POLY(2) 8 0 5 0 (0,0.5,0.5)
* X-INPUT STAGE & POLE AT 15 MHz
IBX1 1 0 DC 8E-7
IBX2 2 0 DC 8E-7
EOSX 10 1 POLY(1) (16,100) (5E-3,1)
RX1A 10 11 5E6
RX1B 11 2 5E6
GX 100 12 10 2 1E-6
RX 12 100 1E6
CX 12 100 1.061E-14
VX1 8 13 DC 3.05
DX1 12 13 DX
VX2 14 5 DC 3.05
DX2 14 12 DX
* COMMON-MODE GAIN NETWORK WITH ZERO AT 560 Hz
ECMX 15 100 11 100 10
RCMX1 15 16 1E6
CCMX 15 16 2.8421E-10
RCMX2 16 100 1
* Y-INPUT STAGE & POLE AT 15 MHz
IBY1 3 0 DC 8E-7
IBY2 4 0 DC 8E-7
EOSY 20 3 POLY(1) (26,100) (5E-3,1)
RY1A 20 21 5E6
RY1B 21 4 5E6
GY 100 22 20 4 1E-6
RY 22 100 1E6
CY 22 100 1.061E-14
VY1 8 23 DC 3.05
DY1 22 23 DX
VY2 24 5 DC 3.05
DY2 24 22 DX
ECMY 25 100 21 100 10
RCMY1 25 26 1E6
CCMY 25 26 2.8421E-10
RCMY2 26 100 1
* Z-INPUT STAGE & POLE AT 15 MHz
IBZ1 7 0 DC 8E-7
IBZ2 6 0 DC 8E-7
RZ1 7 6 10E6
GZ 100 32 7 6 1E-6
RZ2 32 100 1E6
CZ 32 100 1.061E-14
VZ1 8 33 DC 3.05
DZ1 32 33 DX
VZ2 34 5 DC 3.05
DZ2 34 33 DX
* 50-MHz MULTIPLIER CORE & SUMMER
GXY 100 40 POLY(2) (12,100) (22,100) (0,0,0,0,0.1E-6)
RXY 40 100 1E6
CXY 40 100 3.1831E-15
* OP AMP INPUT STAGE
VOOS 59 40 DC 5E-3
Q1 55 32 60 QX
Q2 56 59 61 QX
R1 8 55 3.1831E4
R2 60 54 3.1313E4
R3 8 56 3.1831E4
R4 61 54 3.1313E4
I1 54 5 1E-4
* GAIN STAGE & DOMINANT POLE AT 316.23 Hz
G1 100 62 55 56 3.141637E-5
R5 62 100 1.0066E8
C3 62 100 5E-12
V1 8 63 DC 4.3399
D1 62 63 DX
V2 64 5 DC 4.3399
D2 64 62 DX
* NEGATIVE ZERO AT 20 MHz
ENZ 65 100 62 100 1E6
RNZ1 65 66 1
FNZ 65 66 VNC -1
RNZ2 66 100 1E-6
ENC 67 0 65 66 1
CNZ 67 68 7.9577E-9
VNC 68 0 DC 0
* POLE AT 4 MHz
G2 100 69 66 100 1E-6
R6 69 100 1E6
C2 69 100 3.9789E-14
* OP AMP OUTPUT STAGE
FSY 8 5 POLY(2) VZC1 VZC2 (2.8286E-3,1,1)
RDC 8 5 28E3
GZC 100 73 72 69 11.623E-3
VZC1 74 100 DC 0
DZC1 73 74 DX
VZC2 100 75 DC 0
DZC2 75 73 DX
VSC1 70 72 0.695
DSC1 69 70 DX
VSC2 72 71 0.695
DSC2 71 69 DX
GO1 72 8 8 69 11.623E-3
RO1 8 72 86
GO2 5 72 69 5 11.623E-3
RO2 72 5 86
LO 72 7 1E-7
* MODELS USED
..MODEL QX NPN(BF=1E4)
..MODEL DX D(IS=1E-15)
..ENDS AD633
