Piotr Wyderski
I am designing a prototype charger of a lead-acid battery
used as a backup power supply source. The input voltage
is synchronously rectified 12VAC and the current is <= 40A.
I would like to use LT1185 due to its excellent properties.
Because of other design requirements, the + line is common
and the regulator is connected between the - of the battery
and the GND of the rectifier -- a typical negative voltage
LDO application. The regulator should supply 13.8V/2A when
enabled via the REF pin. However, several questions arise
and I am unable to find an authoritative answer in the PDF.
Will the regulator survive if:
1. it is enabled (via REF) and the voltage on the Vout pin is higher
than on Vin
(but of correct polarity)? This would happen when the battery is
connected and
the voltage from the rectifier is in the decreasing sector of the
abs(sine) wave:
17V*abs(sin(50Hz)) _____________
| - 12V battery
-----X LDO
GND -------------
2. as above, but the regulator is disabled? (Iref < 400nA)
3. the regulator is disabled and its Vin and Vout pins are
shorted (by a 430A-capable NMOS) in order to provide a low
impedance current path from the battery to the supplied device.
_____________
Rload | - 12V battery
| -----X | short circuit
GND -------------
It works in LTSPICE, but I don't know how accurate the simulator is in
these not very standard conditions. Here's a more detailed diagram:
http://s10.postimg.org/rfhbc28hl/charger.jpg
R1 and R12 are actually switches.
Best regards, Piotr
than on Vin
connected and
abs(sine) wave:
| - 12V battery
-----X LDO
GND -------------
_____________
GND -------------
Best regards, Piotr
