Does anyone have any ideas on how to lower the NF in a uhf preamp? I
have two types
one had seperate comopnents and the other is a self contained chip.
have two types
Reduce temperature is the obvious one. Liquid nitrogen (or better).
Dave K MCSE.
MCSE = Minefield Consultant and Solitaire Expert.
Please note my email address changes periodically to avoid spam.
It is always of the form: month-year@domain. Hitting reply will work
for a couple of months only. Later set it manually.
have two types
Actually LN2 is a bit too cool (though I think I get your point) .
In gamma particle detectors - made of a large Ge crystal
cooled down to liqud nitrogen - the preamp FET is cooled
to something higher, about -90 C (rather than the whole -190 C),
they seem to work best there...
Reducing the temperature depends on the type of
semiconductor. A doped silicon one, aka bipolar
may stop working when the usually thermally excited
conduction electrons do not populate the fermi
surfaces anymore. A FET is a completely different
story. There the conduction is done by a field
sensitive channel. FETs can work down to LHE.
Fets are different from bipoar indeed. Perhaps they can
work down to LHe. For some reason, though, the detector
manufacturers opt for about -90 C - all I know is this is
common practice based on extensive experimentation
over the last few decades. Invent a major noise reduction
technique in this field based on your knowledge and get
it sold, I may be among those interested.
It appears that dry ice (frozen CO2) sublimates at -109.3°F or -78.5°C;
I've seen it used in an acetone bath to get not quite as cold as LN2.
Then again, depending on your mounting arrangement, you might not need
any liquid at all - just drop some chunks into a copper chamber...
have two types
