John Devereux wrote...
The "capacitance multiplier" circuit can be used for protecting
a sensitive circuit from noise on the supply rail:
Vin _______ _________ Vout
| \_^
R |
This circuit will drop 1V or so. Is there something with lower
voltage drop?
A normal LDO voltage regulator requires a specific Vin value.
Right, an LDO is not suitable for you.
What I want is a circuit that will track Vin, with only a couple
of hundred mV drop, suppressing anything above a kHz or so.
You have two choices, neither one very attractive. You can use
a PNP or PMOS pass element with an active-regulator circuit that
tracks the average value of Vin, but that's a painful circuit to
make and leaves you with a brute-force compensated output. Or you
can modify your circuit above to drive the NPN base from a voltage
that's 400mV or so above Vin. To get this voltage you'll need to
add a simple dc-dc converter with its output stacked on Vin, and
appropriately regulate its output. For myself, often in this very
situation, I settle for the modest drop across the pass element,
and design the follow-on circuitry appropriately.
One way to improve the attenuation-vs-voltage-drop tradeoff is to
make the filter active by splitting the base resistor and bypassing
it from the output. The resulting 12dB/octave cutoff slope allows
you to use lower-value resistors (less base-current voltage drop)
and still get improved 120Hz and high-frequency noise attenuation.
.. Vin ---+------ | ---- C E ---+------ out
.. | | B
.. '-/\/\--+--/\/\--+---||--- gnd
An issue not always considered in these circuits is, what happens
to the transistor's dissipation in the event of a short circuit?
Unless Vin current limits at a fairly low current, the transistor
may be exposed to a damaging power-dissipation level. I deal with
this issue by adding a collector resistor, like a small 3W WW type
power resistor. The resistor is chosen for less than 400mV drop
at the maximum operating current. The tradeoffs in selecting this
protection resistor reveal one more problem to solve in any attempt
to design such a circuit with a voltage drop under about 700mV.
One last comment. If this type of filter is used directly after
the 60Hz rectifier storage filter capacitor, where the ripple may
be 500mV or more, the 0.5 Vbe average drop won't be high enough to
allow proper filtering. In such a case, using a logic-level power
MOSFET pass element not only gets you the extra voltage you need,
but allows using much higher filter-resistor values, and eliminates
the need for an awkward current-limit resistor, because the MOSFET
delivers high output currents without excessive base-resistor drop.
Following a MOSFET filter stage with a three-terminal regulator is
one way to get a very quiet high-current regulated power supply,
with micro-volt ripple levels.
(One awkward issue you'll encounter is understanding the MOSFET's
subthreshold region of operation to predict the Vgs value. Sadly,
this issue won't be dealt with in the FET's datasheet. Moreover,
available Spice models won't show the correct Vgs value either.
But we do discuss the theory and give you guidance in AoE.)
