Hello everyone. I made Ac to Dc power converter and it looks work. I still have a couple of questions about it.
I uploaded the diagram (see attached file please) and my questions are:
1. Why there is 14 volts before and after resistor R1. R1=15 Ohm and if current is 0.5 amps, voltage after R1 should
be 7 Volts, the load is 12 Volts 5 Amps.
2. Three TIP2955 transistors are too hot 60-70 degrees Celsius for 1.7 Amps per transistor load.![PowerSupply12V8amp copy.jpg PowerSupply12V8amp copy.jpg](https://makerv2.webteractive.co/forums/data/attachments/20/20054-4521bd90d1c1e7585b4e402ffeb8fea6.jpg)
Thank You for your help
Walter
Walter
