Thanks for your comments - the object of my search is to reduce the
height of the SMPS output smoothing capacitor - some of the other
respondants obviously missed (or chose to miss) that point ;-)
It seems that there may be no easy option - I can afford some more
horizontal real-estate - its the height I want to reduce as I want to
use a very slim housing for this and the cap is the tallest component
by far on the PCB. Output ripple is not critical - I'm drawing maybe
10mA @ 200V from the SMPS, and the downstream devices are not
sensitive to a few % ripple. With the existing cap, the SMPS runs at
approx 87% efficiency - it'd be nice to improve that, but its not
necessary and way down the list - physical size is the issue.
At present, most of the ripple in your circuit is actually due to the
electrolytic's ESR - which will be in the region of 10-50R - a typical
value for small high-voltage electrolytics. Depending on the mfr's
thermal impedance model, the ESR of the actual part used is 47R
(200mW) to 118R (500mW). There is a lot of competitive fudging going
on where ripple current ratings for small electrolytic packages is
concerned.
Even assuming a minimum operating frequency of 20KHz and the peaky-est
converter topology, the actual required capacitance to provide this
kind of ripple at 10mA is less than 0.1uF.
If you don't have access to the original design notes for this
circuit, you may not be in a position to determine what the design
factors were in selecting the original 'oversized' part.
My suggestion is tha you try 0.1uF X7R 250V in parallel with: {a
network of .47uF X7R 250V in series with 50R 350mW}, over the entire
load and operating temperature ranges required - while examining
turn-on, turn-off and stability performance of both the converter and
the system in which it is used.
None of these alternate components is particularly expensive, and all
have a low profile. The total component cost WILL be higher, and the
real estate consumed will ~double, but if your testing and
observations allow it, you will have achieved your intended magic
trick.
RL
