Ive read a post about a generator starting and cutting out after a while of running
It refers to a signal conditioner box on the side of the engine, I understand ftom that that the sensing is probably too sensitive in this application..ie that the low oil signal is received when oil is splashed onto the interieur if the crank case hence lewering the oil level enough for the signal conditioner box to receive a low oil warning and latch hence cutting out the ignition system
My question would be how to overcome thus problem without losing the low oil protection system
Is it as simple ad "overfilling" the crankcase and make up for the oil level dropping to below the low oil warning level after starting?
I know to dusconnect the sensor solve the problem but I guess that will come back to bore when the oil level drop too low and there is not low oil cut out feature?
