Bob Engelhardt
The project:
I am making electrically heated socks & gloves. For power I'm using the
9.6v NiCad batteries from my cordless drill. The working assumption is
that each sock & glove will need 1w, but that's very tentative & I'll
have a regulator to adjust as needed. The critical parameter is the
9w-hr available from a battery before needing to be recharged. So the
regulator must have minimum losses. The 2 socks & the 2 gloves will be
in series & independently regulated.
The current plan is to use a 555 timer for each pair & vary the duty
cycle to achieve regulation. But the 555 can't drive the heaters
directly - they'll require about an amp. I'm thinking of using SMT
BJT's from ON Semi:
http://www.onsemi.com/PowerSolutions/parametrics.do?id=808
because the very low VCEsat (as low as 50mv) will minimize the regulator
losses.
The questions:
- is there another device that I could use instead of BJT's? Switching
10v & carrying an amp at low loss (1/10w +-). (OK, now it's obvious - I
don't know anything about semiconductors <G>)
- are there through-hole BJT's with very low VCEsat? (I've not used
SMT's & I suspect that they'll be a fabrication challenge.) Googling on
"low VCEsat BJT" was not helpful.
Thanks,
Bob
BTW - I hang around rec.crafts.metalworking mostly & when I subscribed
here I was REALLY impressed the the minimal amount of OT posts. No
political OT that I recall. Keep up the good work.
BJT's from ON Semi:
losses.
The questions:
Thanks,
Bob
