Hello. Nice to meet you all here! I have a question to ask you and I am not sure what is causing the issue.
I have an older SONY Dream Machine clock radio Model ICF-C218.
I brought it out of storage after 5 years and now again, using it. However, I notice now coming directly from the single speaker on top of it, a low hum. I mean you have to put your head and ear almost over the speaker to hear the low “hum” (not really a “buzz”). I thought that to be strange, since the radio (both AM and FM frequencies is off), plus the alarm; and yet it is still emitting a low hum through the speaker. There should be no sounds at all being emitted from the clock radio speaker when the radio and alarm are totally off. The only way to eliminate the low hum is literally unplugging the clock radio’s power cord from the wall and shut it down (powered off). NOTE: When the radio is on and the volume is very low, I still can hear the low hum in the background; but when I turn the volume up the low hum is overshadowed or masked by the radio’s own sound like music playing for example. I have been to other rooms with clock radios in them (different brands), and none of the other ones emit a low hum when their radios are off but plugged into an outlet for power.
This SONY clock radio is out of warranty and I am not seeking any repair or replacement from SONY at this time, as obviously the cost of a factory repair technician is going too far exceed the cost of a new or used one ($10-$30); just need to know if this issue is a problem (malfunction) that could result in fire or physical harm in the future. Also, if it is something a novice like me can easily low-cost fix such as a simple part replacement and simple soldering the wired connections I can handle, please let me know or suggest what would need repairing or replacing.
Please reply.
Thank you!
Please reply.
Thank you!
