On my Phonic mixing console the headphone pot is erratic. Sometimes I cannot attenuate the left channel. I reverse-engineered the circuit around the pot and it is a standard inverting opamp design. The pot's one end is connected to GND and abviously this GND connection is cut sometimes. It is not a "dirty middle contact" problem. It is also not a problem with the PCB, because I connected the GND pin to ground using a wire and this didn't change a thing.
So the disconnection must be inside the pot. Even when it works and I turn it down, the resistance between the middle contact and GND is a couple of Ohms as opposed to 0 Ohms on the other channel. I could live with that.
Problem is, I cannot easily replace the pot. This would require removing 100 pot knobs, removing two other PCBs and the PCB in question would still be connected to another PCB via 20 soldered short wires and what not. This would probably cause more harm than good. I can only access the pot from the soldering side and I can wiggle the knob.
The pot looks like an ALPS RK12L1230C0K to me:
When the error occurs I can usually "fix" it by pushing the knob down. I also resoldered all pins and this also fixes the problem temporarily. The strage things is, that once it works it works for several hours and I can use it, turn the knob and all without any indication of a loose contact. . It is as if it "clicks in" into normal mode and stays there. As if a spark temporarily welds the disconnection, but I cannot see why there would be enough electrical power to create a spark strong enough.
Can anybody explain why the problem "clicks" into non-existence?
Does anybody know how these ALPS pots look on the inside and could give some guidance for fixing it in place?
