Hi All,
I am working on a project for the into High school physics class I teach.
I want to make a small battery driven Peltier cooler, but am limited to a max input of 9V. The Peltier plates I have appear to be most efficient at currents around 5A. I can use any combination of non-Lithium (school restrictions) batteries as long as the final output voltage does not exceed 9V. As a result I cannot just put some 9V batteries in series to up the voltage past 9V. The high current does not need to last vary long, a max of 10 seconds in fact. I also need to cool the Peltier quickly looking to drop the temp of the cold side about 30°F in less than 10 seconds (that is why I don't care if the battery are drained after 10 s).
I can use transformers to boost the voltage but still need high enough current to drive the Peltier. I have an adjustable VDC to VDC step up that I can put my 9V max in and get 12V out but still need to get the 5A out.
Is there any combination of batteries that can provide the 60W power to get 12V and 5A out. I can use any combinations of batteries as long as the output is <9V.
I have tried 4 x 9V in parallel but can only get 2.4A out.
Any suggestions?
6 x D, C, AA, AAA?
6V lantern batteries?
Thanks in advance.
Any suggestions?
6 x D, C, AA, AAA?
Thanks in advance.
