Looking For RCA Video/Mono Audio Input Jack For TV
Please see the attached picture. I am trying to repair my Sanyo Model DS19310 TV. Over time, the RCA input jack wore out, and failed to work.
After removing from the main board, it appears some of the metal wire broke away from the board, above the weld. I am going to attribute to the problems I am having with this jack.
Does anyone know where I can by a new one of these jacks?
Where are you at?
The jacks themselves are readily available, but you might have a problem finding
the exact housing to just solder back into place.
Thanks for the reply. I ended up modifying the housing so I could insert all four metal ends into the circuit board. This did end up fixing the audio, but the video still did not work, even though all 4 solder points appeared ok. So unfortunately I ended up giving the TV to the local electronics recycling dealer today, and that's the end of it.
OOooooo,.... Sacrilege.
Maybe you had video problems not associated with the RCA jack, but we never
give up that easy, without at least a fight.
Where's your respect and appreciation for all those Japanese engineers and technicians
who designed and built that state-of-the-art audio/visual device?
Next time, give us at least a chance to help with the fix.
