McWired
I want to build a board to connect a microcontroller to a TFT
display. The board consists of the microcontroller, a programmable
device and a FPC connector for the screen. Since I want to test
different screens, and each of these has a different pinout and line
number for the FPC cable, the programmable device is needed to
reroute the lines from the microcontroller and the power supply
lines. Basically, it should consist of a latch block to hold the
address lines, bidirectional data lines and control/status lines, and
power supply including ground. The output current for the supply is
maximun 50mA, and the switching frequency at about 5Mhz.
The FPC connector will be soldered according to the cable size, since
the board will have a large array of connection pads to accomodate
this part.
I've never try a FPGA neither a CPLD so that's new field for me, but I
think that is the type of component that I should use to interface the
microcontroller with the screens. Any comments will be highly
appreciated.
Mark.
this part.
appreciated.
Mark.
