Aaron407
Hopefully someone can help me, I've spent hours searching the internet
for a solution to no avail. I'm looking for Uninterruptible Power
Supplies that can be connected in parallel for best redundancy to
protect a DCS panel. I'm aware that there are many UPSs that support
the N+1 or N+X systems for the power cells, but still use only a single
controller. However, we've seen problems in the past where the
controllers malfunction on a UPS and, as a result, it failed to back up
the systems regardless of any redundant power cells. Therefore, two
distinct systems (with separate controllers) with the ability to be
connected in parallel (ie. 1+1 setup) is definitely the setup I'm
looking for, but, as expected, their outputs need to be phase locked.
Specifics of what I'm looking for are as follows:
Input: 120V AC or 208V AC, 60Hz (common supply to both units)
Output: 120V AC, 60Hz
Power: 2300W < Output Power < 3300W (for each unit)
Mount: preferably tower/floor standing, but 19" rack mount if nothing
else is ok.
Electrical bypass: preferable for maintenance and replacement of UPSs
If there are no UPS systems specifically designed for this setup, is
there any kind of interface that can be used to phase lock the
individual outputs of two identical UPS units?
I'm hoping someone can help me in my search. Any help at all would be
greatly, greatly appreciated.
-407
else is ok.
-407
