Looking for motor testing houses
Hello all. I'm looking to find companies in the United States that
perform testing and evaluation on small brush-less DC motors. I'm
talking about generating torque/speed curve profiles, dynamometer
testing, winding resistance and inductance measurement, etc., not just
"yeah Wally, it spins real purdy!" kind of testing. The motors I'm
interested in testing are ~1/4HP or ~200 Watts and max unloaded RPM of
~10,000. So far searching on Google has only lead to a single
reputable lead... I'd like to avoid having to get all the equipment
myself since this is a one or two time testing and the equipment is
too pricey to justify it. Thanks in advance!
-Will
-Will
no idea buddy,but dont wary i m your friend u can talkto me
Sounds like a real specialty shop.
Is this for some sort of QA function? Or are you trying to find the
motor parameters as the basis for some design/analysis work? If its the
latter, can you get the data from the manufacturer? If not, your best
bet might be to look for a cal-cert lab that deals with
electromechanical transducers.
It is for QA. Essentially we have an old motor vendor we're not too
thrilled with and a new motor vendor we're feeling out. We want to
take samples of each and compare/contrast them, but also check the
real world numbers objectively. We know what the numbers *should* be,
but we'd like to verify that's what the numbers actually *are*.
-Will
H
-Will
Couldn't you make up a dummy load of a generator connected to the
output shaft of the motor, and then using a strobe and ammeter measure
the current draw for various loads / speeds and do that for both
motors to see if they draw comparable current for the same load and
speed?
