So, I am going to design a Buck Regulator Power Supply, and I was looking for input and advice.
Here are the spec's I need:
Input voltage: 400-480 VAC, 3 phase.
Output voltage: adjustable to 400VDC
Output current: up to 100A. (40kW)
Am thinking about using a PWM controller (TL594?), and a single IGBT switch rated at 1200V / 450A. (Infineon art # FF450R12KT4, switching at 20kHz)
The supply is essentially a capacitor charger, (26000uF) that feeds a Plasma Pulse Generator. I don't need it to be isolated, as the plasma generator is an IGBT H-Bridge driving a step up transformer, so I will be isolated there.
My question is, I have never used a PWM Controller, are they designed to work to give you an adjustable output? Or are they more suited to a fixed output supply application?
I have the data sheet, and will try to decipher it later tonight.
I just wanted to know if anyone has any input or advice on this.
(BTW. Don't worry about my skills or the high voltage dangers. My plasma generator currently puts out pulses of over 1MW, and I know what I am doing.)
I am currently wasting a lot of money using off the shelf AC/DC supplies, and they are overkill and cost way too much!
I estimate I could end up building this for a lot less that what I pay now.
