I
Ian Sutherland
Hi folks, I need some direction in diagnosing a condition that I have
created. I wanted to install a 2 Kw. fan heater under my computer
desk, didn't want to have just high & low settings, but wanted the
heat to be continuously variable.
I have built up a circuit that works really great, stepless control
from off (actually 1 cycle every 3 seconds, to full on) The problem is
that now the monitor "Jitters."
The control is a SSR driven by a 555. The SSR has built in zero
crossing detection, the 555 outputs a pulse about 8 ms long to trigger
the relay & a repetition rate adjustable from about 3 seconds down to
about 10ms (to switch the relay on every cycle.)
I thought it might be the current surges causing the jitter, but I'm
sure thats not the case. The jitter remains the same whether the
element is being pulsed at 3 second intervals, or is on continuously.
(This would be the same as the heater prior to the mods.)
The heater has a built in thermostat that I left in & this is in the
neutral line, so I turned it down 'till the elemnet swiched off, the
jitter remained. I guess it's coming from the 555 switching (maybe the
8 ms. pulse) & perhaps ferrite beeds will cure it.
I would be interested to hear any coments regarding fixing the
problem
T.I.A. Ian Sutherland.
Since re-reading the above, maybe the short pulse is not the
culprit, with the elements off (T/stat turned down) & the pot set to
off (1 pulse every 3 seconds) the jitter remains constant, about 2 or
3 cycles per second. Ian S.
problem
