Hi again,
So i'm looking at exercise 1.6 on the right hand column of page 7:
New york city requires about 10 to the power of 10 watts of electrical power at 110v. A one foot diameter pure copper cable has a resistance of 5x10 to the minus 8 ohms per foot.
-Calculate the power lost per foot
-the length of cable over which all 10 to the 10 watts of power would be lost
- the solution to the preposterous seeming answer to the above question.
I got:
- P= V squared / R. This means P=12100 /5x10 to the minus 8 = 2.42 times 10 to the 11 watts per foot.
So, all 10 to the 10 watts gets used up in less than a foot?
My solution is to use AC rather than DC power?
The next question I'm looking at is on page 11, exercise 1.9
It refers to a picture 1.10.
It asks if the Vin is 30v and r1 and r2 are 10k, find the output voltage when:
- the output voltage with no load attached
- the output with a 10k load attached
- the Thevenin equivalent
- The power diappated in each of the resistors.
I got:
The output voltage with no load attached is Vin x R2 divided by R1+R2 so 30x(10,000/20,000)= 15v
With a 10k load attached it is 30x(20/30) = 20v
the Thenenin equivalent, To calculate the Rth valve I did R1xR2/R1+R2 = 200,000000/30,000=6666.666667 so Rth is 6666.666667 ohms
To calculate The short circuit current I did Vin/R1 and got 0.003 amps
To calculate Vth I did Rth x I = Vth and got 6666.666667 x 0.003 = 20 volts
So I calculated that the power dissipated in each resistor as P=I x V which is P= 0.003 x 20 = 0.06 Watts
So, How much did I get wrong!
