Logic family compatibility
Dave Boland
I spent a few days doing homework on what logic family and
voltage was compatible with what. This was a lot of work
because each vendor has their own spin on the specifications
(which makes me wonder why standards even exist, but that is
another story).
Below is my take on things, and I would appreciate your
comments if I have it wrong, or something is incomplete.
I refer to CMOS, NMOS, etc. as xMOS.
From To
TTL: TTL; LVTTL*; 3.3V xMOS*, LCX*, LVC*; LVT*, LVX*
LVTTL: TTL**; LVTTL; 3.3V xMOS, LCX, LVC; LVT, LVX
xMOS, 5V: xMOS 5V; 3.3V xMOS*, LCX*, LVC*; LVT*, LVX*
xMOS, 3.3V: TTL; LVTTL; 3.3V xMOS, LCX, LVC; LVT, LVX
'L's, 3.3V: TTL**; LVTTL**; 3.3V xMOS, LCX, LVC; LVT, LVX
*5 volt tolerance required, which they all seem to have today.
**Make sure that the Ioh is high enough to drive the loads.
Driving 5 volt xMOS is difficult because the Vih is .7Vcc,
or about 3.5 volts. Thus, a 3.3 volt part can't do this
without a device like a 74LVC4245 or 74LVX4245.
John Larkin
another story).
From To
When a 5-volt family drives a lower-voltage CMOS part, you run the
risk of forward-biasing esd diodes and poking current into the Vcc
rail of the victim chip. This is especially bad for 5V CMOS driving
3.3 or lower CMOS, as the curents can get high. Lots of lvcmos parts,
including FPGAs, are *not* 5v tolerant!
TTL doesn't pull up as hard as 5v CMOS, but enough to poke some
current anyhow; the schottky families are worse than classic old TTL.
And some TinyLogic cmos parts and older FPGAs can be pulled up to +5
or so without drawing input current.
My test guys came to me last week with a bunch of boards that had the
3.3 volt FPGA supply running 3.7 or something. I was driving the
Xilinx FPGAs from a 5-volt CPU, with 100 ohm current-limit resistors,
and it still pulled the supply up. I scaled down the sense resistors
on the 3.3 volt reg to dump more current, and that fixed it.
Right now, we're doing a board where we'll run the 3.3 volt rail at an
actual 3.5 to guarantee we can legally drive some 5v cmos stuff.
All these different supplies are a real pain. They should have stopped
at 5.0. The Spartan3 chips need 3.3 (or 3.5!), 2.5, and 1.2.
John
Jim Thompson
John
It's all driven by scaling... smaller geometries are faster (and take
up less chip area per function), but can't tolerate higher voltages.
My general rule-of-thumb for nominal voltage is 10X the dimension in
microns, thus a 0.18um process runs on 1.8V.
It's about to come to a halt though... those short-channel devices
leak like sieves.
...Jim Thompson
Jonathan Westhues
How does the ESD protection network work in (legitimately) 5V-tolerant
logic? Do they just add a few more diodes in series with the diode to Vdd,
or is it more complicated than that?
Jonathan
K
keith
It's usually more complicated. There may be stacks of diodes as a
reference, but there is often some fold-back or latching built in as well
as a filter to discriminate an ESD event from normal power sequencing.
ESD tollerence is an art and there are a kabillion ways to do it (I know
an individual with a hundred patents on such things).
John Larkin
Jonathan
Gosh, I don't know; maybe Jim does.
Some of the TinyLogic cmos parts can tolerate 7 volts or something
with any or no Vcc, so there's likely no clamp path to Vcc at all...
maybe a zener?
John
K
Ken Smith
Some parts use a special MOSFET to ground. The MOSFET has a very high
Vgs(th) and a low gm.
The real bummer is on things that can drive busses. The pull up
transistor of the output section provides a direct path for an above the
rails signal to get into the substrate and cause troubles.
Dave Boland
Dave said:
I spent a few days doing homework on what logic family and voltage was
compatible with what. This was a lot of work because each vendor has
their own spin on the specifications (which makes me wonder why
standards even exist, but that is another story).
Below is my take on things, and I would appreciate your comments if I
From To
Driving 5 volt xMOS is difficult because the Vih is .7Vcc, or about 3.5
volts. Thus, a 3.3 volt part can't do this without a device like a
I agree that all the different voltages is a pain in the
butt. However, what I really need to know is did I get it
right?
I'll be connecting a 3.3V xMOS processor's I/O pins to the
outside world and I want to protect it from voltage
mismatches, so I plan to buffer the processor with a 3.3V
'L' part that will drive 3.3V xMOS, TTL, and can be driven
to 5V when used as an input.
uP Buffers (LVC??)
|----->| |----> 3.3V xMOS, LVTTL, 5V TTL
|<-----| |<--- 3.3V xMOS, LVTTL, 5V TTL
Thanks,
Dave
John Larkin
right?
uP Buffers (LVC??)
Thanks,
Dave
Sn74ALVC164245 is a nice part. 16 bits of level shift, cheap,
multi-sourced.
John
Jim Thompson
Yes. However it's all proprietary. But the basics are that P-channel
devices are built into N-wells. With proper design you can get the
P-channel device to turn off and the N-well to float up.
This is also the way parts attached to a bus can be unpowered and yet
not load the bus.
maybe a zener?
John
...Jim Thompson
Dave Boland
multi-sourced.
John
John (and others),
I agree, but that part is needed mostly if driving 5V xMOS
due to its high Vih, which is .7Vcc, or 3.5 volts.
What I really need is for a lot of experienced people to
look at my chart (above, along with text) and tell me if I
got it right. Once I feel confident that I understand the
compatibility, it should be a simple matter to design the
logic.
I practice, the logic will likely be an 08A quad AND gate so
the processor I/O can enable/disable input and outputs. This
is not the same as tri-stating, just useful in some limited
situations.
Thanks,
Dave
G
Greg Neff
On Mon, 11 Jul 2005 16:34:59 -0700, John Larkin
(snip)
John
I'm working on a DSL MODEM design now using a Mindspeed g.shdsl chip
set and a Spartan 3 FPGA. The parts need 1.2V, 1.8V, 2.5V, 3.3V and
12V. The power source is 5V. Half the real estate is power and
supervisory stuff. This was a major PITA because we only had 8 square
inches (total) to work with.
Another FPGA gotcha is cases like the SpartanXL where the outputs are
5V tolerant. Prior to configuration done the IO pins have weak
pullups to 3.3V. If you are interfacing to a circuit with resistance
to 5V, then these IO pins will actually sink current to 3.3V until the
FPGA is configured.
Greg Neff
VP Engineering
*Microsym* Computers Inc.
[email protected]
John Larkin
On the board we're doing now, certain overly-cautious engineers (you
know who you are) noted that 3.3 wasn't a legal high for some of the
cmos parts, so I just made the executive decision to run the Xilinx
stuff at 3.5. This board has 16 isolated DAC channels, each under two
square inches.
John
