Platforms
Content
why are you looking for a replacement?
operating temperature range from -30 to 70 degree C.
They are completely different:i think TL082 is identical. i used it in some circuits instead of lm358 and worked the same.
Can I consider these 2?
Did you check their datasheet?
And it's an LM158
Yes i have checked their their datasheets.
There are thousands of dual opamps with the same pinout; it is an (unwritten) international standard.I have also found 2 more alternate ICs for LM358 with same pinouts and my requirements.
Can you post a portion of you schematic so we can evaluate your choices?
ak
Maybe it isn't the part, but the way it is being applied.2.I am observing failure of this IC in most of the application. So I am searching for the replacement of this IC other than LM358 family.
