Hi all,
I have used the LM3410 LED boost driver multiple times in the past, but I am busy doing something different and would like to know if the circuit below would function as I desire.
Basically I want to use the LM3410 to power 3 LED strings at different times. The LED strings will be driven at the same current, but because of the differing LEDs between each string, the forward voltage will differ. I need a way to properly switch between which string is being driven. I am doing this so that I can use 1 driver circuit instead of 3 separate circuits.
My solution is relatively complicated, so I'm open to improvements.
The biggest problem I face is ensuring that the output from the LM3410 boost circuit has no connection if an LED string is not connected. This is because the LM3410 circuit may be receiving power without a load connected. This should never happen, but I am using a mechanical switch to move between each string so the chance is there. The only way I can see to solve this issue is by isolating the output capacitor from everything until an LED string is activated. So in the circuit above you have 3 on/off inputs. Only one of these can be activated at a time:
- VIN is providing power to the boost circuit. No FETs are on. Nothing is connected to the boost circuit's output. The LM3410 is not doing any boosting then.
- FET1 is activated which also activates FET4. This connects LED STRING 1 and C_OUT to the output of the boost circuit.
- FET2 is activated which also activates FET5. This connects LED STRING 2 and C_OUT to the output of the boost circuit.
- FET3 is activated which also activates FET6. This connects LED STRING 2 and C_OUT to the output of the boost circuit.
The reason for the 3 FETs connecting to C_OUT is because if the LM3410 has power and C_OUT is connected but no LED string is connected I don't think C_OUT will last very long before the circuit destroys itself! C_OUT needs to be isolated from the 2 strings that are not connected otherwise it will induce a reverse voltage across the 2 off LED strings which will destroy them.
Apart from needing 6 FETs this looks as if it will work to me. I've identified this FET as possibly being suitable for the job. It's cheap and small so it may be possible to do what I need to do with this.
Good? Bad? Any recommendations would be highly appreciated.
Thanks,
- Matt
Thanks,
- Matt
