AJ
HI,
I am currently using a LM311 as a V-F. I have it set for 150mV/Hz with the
following components.
Rt = 200K
Ct = 100nF
Rs = 13.8K
Cl = 1uF
Rl = 100K
For testing I have used some components that I have had laying around and I
am finding that the output is greatly effected by temperature. The
resistors are surface mount metal film but I have used an XR7 for Ct and a
Tantalum for Cl. The datasheet recommends NP0 or C0G series for Ct and I
have found one with 30ppm/C in an SMT package ok but it also says I should
use a Mylar Cap for Cl. I have had a bit of a look around and the only 1uF
Mylar caps I can find are huge and not available in SMT. Can anyone
recommend a good choice for Cl? I was also wondering if Cl had to be 1uF, I
am guessing it does but the datasheet isn't very clear, maybe I could use a
smaller value?
Best regards.
AJ
Rt = 200K
Ct = 100nF
Rs = 13.8K
Cl = 1uF
Rl = 100K
smaller value?
Best regards.
AJ
