Hi folks,
I purchased a voice activated recorder from a far away land and it's not working right. I think the charging / battery part of it is messed up.
There is an internal lithium button battery that is supposed to charge by USB. The device doesn't do anything when it's untethered, but when it's plugged into USB, it does what it's supposed to. (USB drive, charging light, etc.)
I have gained tentative access to the battery.
The battery is small, and has a red and a black wire soldered a small distance apart on one side. The other side has a black sticker, probably hiding the specifics of the battery.
I can measure 1.9 v dc at the solder points when it's hooked up to USB, but the same points read nothing when it's untethered.
I don't want to send the thing back for an exchange if I can help it, (might never see it again) but am trying to keep that option open by not leaving any evidence that I've cracked it open. That's why I don't take the sticker off the battery just yet.
Anyway, my newbie questions are these:
With the voltage I measured, how long would it have to charge in order to fill up that battery?
Do batteries just quit as I think this one has?
When it's untethered, if the button battery shows dead, could I take a AA battery and run test wires to the solder points on the button battery to give it some juice and see if that makes the thing work -- without causing damage to anything inside, assuming I don't klutz it up?
The solder points on the battery are really, really tiny and I'm kind of hamfisted and unskilled; if the battery is not accepting a charge, is there any way to 'wake it up' without replacing it?
Lastly, has anyone seen a little silver lithium button battery that has two solder points on one side? It's supposed to be able to record a couple hours of digital voice data.
I appreciate any help anyone has to offer.
Thanks,
Dave
Thanks,
Dave
