Can anyone verify my design for a light/ dark sensor i made (see attached image for the schematic)
Operation:
My design is a dual mode sensor. it could be set as a light sensor or a dark sensor.
SW1 would set the mode of the device. Flipping the switch would interchange the position of the resistors( R4+VR1) with the LDR. This would determine if its a light or a dark operated sensor.
SW2 would set the sub-mode of the device. Sub-mode 1 ( SW2 at C-B;E-F) would just be a plain sensor, output depends on what is sensed by the LDR. Sub-mode 2 (SW2 at C-A;E-D) would be a triggered sensor ( Continuous output once triggered regardless of the following conditions sensed by the LDR).
VR1 will determine the sensitivity of the device.
Thanks in advance .... any suggestions would be greatly appreciated.
Note: If the design would work pls help with what component names and values i would put on the final product tnx...
Operation:
