Platforms
Content
If the bulb replaces the loudspeaker, i.e acts as a dummy load, then clearly the loudspeaker is protected .in place of actual speakers
.... but maybe < 50 Ohms when cold.A 120v, 60w bulb is 240 Ohms....
True.but maybe < 50 Ohms when cold
Did you mean use the bulb as a dummy load, or use the bulb in series with the speaker to limit current?
Bear in mind that the bulb rating specifies wattage at the rated voltage when the bulb is hot. The bulb's cold resistance is a lot lower than its hot resistance.
An electric kettle element would run at a lower temperature than a bulb filament, so the hot/cold resistance variation would be less.
True -- with clusters! Less because of the lower temperature, and less again because heating elements are typically made from wire (e.g. nichrome) with a much lower tempco (e.g., ppm/C vs ppk/C) than tungsten.An electric kettle element would run at a lower temperature than a bulb filament, so the hot/cold resistance variation would be less.
