D Yuniskis
One of my portable DVD players uses a (nominal) 7.4V 2600mAH
Li-Poly battery. One cell appears to be toast (*loaded* voltage
RAPIDLY drops from ~3.5V to ~1.8V after ~10 minutes of use;
other cell holds fast at ~3.5V).
I was thinking of replacing them with a pair of 18650's
as they occupy almost exactly the same space (different,
though compliant, form factor; same volume -- of course!).
It is my understanding that the charging technique for
LiPoly and LiIon are identical (?). I'd prefer not to have
to reengineer the charger (microcontroller controlled).
[Given my druthers, I'd replace with NiCd but that would
require way too much work!]
Any other pointers to watch for (besides the usual, "OMG!
You can burn your house down!!")?
Thanks!
--don
P.S. pointers to a source/manufacturer of reliable *tabbed*
18650's would also be welcome. (though I may just opt to
cannibalize some laptop battery packs)
Thanks!
--don
