Hi there!
I have an induction stove. And it has been working excellently for 16 years!
Until the right side stopped working.
I really want to put this working again! Mostly because it's cheaper and more ecological. So I hope there is someone there that can help! (I upload image of the stove's inside.)
Opened it up and saw four burnt components (resistors R11 R12 and transistors Q3 Q4, see images) on the main PCB. Got those through the internet, substituted them and turned it back on. (The resistors I bought are green 48 Ohm 1W power and a bit larger)
Result:
Just my luck; the left side went dead
But the right side worked fine... for three days :-(
Opened it up and Q4 definitely seems to have AGAIN a burn mark!
Action:
Wait for your advise on how to proceed with the right side.
From comparison between the two identical PCBs I substituted on the left side the 68 kOhm R31 and R32 resistors(see image) as these seemed clearly to be off mark with a multimeter reading as compared to the color code and the left PCB board.
Result:
Right: on hold
Left: Back from the dead ... but zombie-like, because one plate works fine, the other plate works fine, but if I want to use both of them, then one just falls away (display starts to blink and after a while it disconnects, as if no pan was on it). It did this for some days, but today it decided to behave and work properly! How starnge is that!?
Any advice here is very welcome.
R.A.
Result:
Action:
Result:
Right: on hold
R.A.
