I'd just increase the apd gain untill your resistor noise gets lost below
Good idea, but i hope it doesnt really brake down, will first meausure
dc current through it, maximum is 1mA i believe...
500mhz gets interesting as even very small wires have significant inductive
impedance to be a nusiance.
you can even use a TV to see what frequency is !
im using several 3ghz+ MMICs to drive the laser and will probably use them
for the APD bias too.
Thats quite low, high eficiency lamps emit lots of noise in this range wich
will go straight through the mixer.
Yes i know, 455Khz should probably be the best...
I am now using 2 old Shwarz(i dont remember the name exactly
frequency generators who can go up to 1Ghz with 1.5V pk-pk amplitude
that sounds about right, maybe your diode has a much lower vbr than mine.
That would be strange but who knows...i will try up to 250V , first
have to check datasheet again but i believe it was 250V, espescially
the c30902S APD, it can operate in geiger mode, but i only have the E
type... i also saw some interesting APDs from hammatsu with much less
noise , less reverse bias voltage and same gain... (S9717 APD). Also
the C30902S-TC is interesting as it is cooled , but i don't know the
prize, will be too high probably!
thats indeed the main criteria, as much AC power transmit as
possible..
I cant find good datasheets, im stil using a cheap laser pointer type diode
too.
I might go for one of the VCSEL types.
I use
http://www.roithner-laser.com/
aha , interesting, will look into them
2mh for 455khz wich is quite large, hard to find a well sheilded one.
10khz becomes unpractical.
Im probably switching to 6mhz IF so a much smaller inductor and use a TV IF
sound trap BP filter.
yes but then your amplification will drop... hows your sensitivity, can
you measure up to 100 meters...? i am intending to use the DSP blackfin
from analog devices to do all the measurements and averaging soo i can
easily average out the noise...
ah no what I meant was that you need a path for the bias frequency to go
through apd and down to ground, otherwise you end up with no bias frequency
voltage accross the APD.
Ofcourse Colin, but i meant at the input of the amplifier, i bias the
diode at the other side, with a 56 ohm resistor between the 217V DC
voltage and the AC modulation signal (with high voltage smd cap in
between).. then the other node of the APD is at the input of my amp
with a resistor to gnd... here i am going to put a cap in parrallel
with this resistor to filter out the high modulation frequency..( but
the other node still has this freq soo the mixing still hapens).I was
wondering if i could use a 10Meg resistor then the parasitic cap would
be high enough to filter everything out above the IF freq... but then
the dc biasing becomes a problem... but still if you could then bias
the diode at 500+ voltage and then have a 300 V on this resistor (due
to the dc current through the diode) , the S/R ratio would be much
higher than now... (if resistor noise is the dominant noise factor
ofcourse)
sounds like the noise from your resistor is quite high, what bandwidth ?
maybe its rf pickup.
the bandwidth is just white noise... it follows exactly my filter... i
did a FFT (fast fourier transformation with my digital scope) and it
looked like white noise)... i also put a speaker at my output so i
could hear the signal
(till 14Khzmy ears could handle
) and there
was no Rf pick up, it sounded like white noise and only my signal was a
beep...
does it agree with calculations ? if its a factor of 2 below APD noise then
its reasonable.
the calculations for apd noise at a given bias voltage, temp AND incident
light are quite complicated but given on the datasheet,
I managed to make my measured noise agree with it. I get close to maximum
demodulation efficiency.
the resistor noise is negligble by comparison.
If you use synchronous demodulation then the noise disapears through the
floor anyway.
I have to do the calculations for shot noise, but measurements dont
lie... but upping the reverse bias voltage can maybe help, and then
lower the gain of my amplifier...
synchronous demodulation ?
With the transistor biasing method it just acts like a current source with a
low frequency negative feedback to keep the gate voltage constant. the
collector goes to the APD and (not the emitter) so is high impedance, the
apd DC current is taken away through the emitter with a resistor as part of
the low freq feedback path.
another simpler alternative just for removing dc bias is
apd
___|____to amp
100k |c
b|_|/ npn
| |e
C=10n R=1k
|__|
gnd
it looks like a ~100k resistor at AC but 1k at DC
Damn, This is a very good idea, its actually the same as a current
mirror, were the APD Dc current determines the set point of the
transistor and because the input impedance of the common collector
(seen from the base) is much higher then the 100K, the Collector
current is the same as the APD's DC current... and for AC the gate
voltage is 0 ... very good idea...i wonder if it is not better to use a
NMOS in stead of the bipolar transistor as the input impedance is much
higher and the need for the 1K is not nessecary anymore... (hmmm if vds
does not decrease too much ofcourse due to signal swing) which improves
the noise (no thermal noise of resistor but probably not an issue
because it is 100 times smaller)...or am i missing something here?
I thaught of something like this before but then with a cascoded
current mirror (to increase output impedance even further) but then i
biased this current mirror with an external resistor which gave APD
bias problems when the DC current of the APD was much different, didnt
think about the feedback to the drain/collector soo the APD's dc
current is used.
My vco goes from 800mhz to 2.2ghz, gets hard to make a simple VCO with such
a wide range above this.
Which VCO ic do you use? Does it have sweep capabilities, i am planning
to try FMCW principle also (frequency modulated continious wave) , then
good resolution qnd sensitivity can even be possible with normal PIN
photodiode..
the limit of the APD is not difusion current limited but RC time constant
Ah thats possible... but i remember that diffusion current speed is
also limited not much above these frequencies...
as for the laser diode im not sure, as its effectivly an oscilator that has
to start up.
indeed... i was also planning todo speed measurements with doppler
effect, in theory much simpler then distance... but the problem is that
the frequency counting must be really precise and modulation frequency
very high...(at 1Ghz ist about 1Hz for every 0.5feet/sec)
soo its a pity
thanks for the good info again!
Yannick
