Hi, please can you help?
I'm an electronics newbee and need to create an LED photographic lighting array inside a small aluminium geodesic dome. I want approximately a 200W output, using 45 - Cool White High Power 1000LM LED Lamp SMD Chips, or similar, connected in series. (The number of chips is important for evenness of lighting). The aluminium shell will be used as a heat sink with thermal paste.
I want to power the array with one or more 12v computer-type power adapters and have the facility to dim the lights.
Please can someone suggest what wattage/voltage LED's and power adapter I should buy, and what additional components I will need for this project?
Many thanks!
David
Many thanks!
David
