LED voltage bar graph
I'd like to have a "bar graph" of LEDs tell me how far along my 6V SLA
is on its charging.
I saw this, but I think it's overkill:
http://www.national.com/mpf/LM/LM3916.html
http://dan.pfeiffer.net/train/vmeter.htm
5 LEDs would be plenty.
Any suggestions for a discrete version of the LED voltage bar graph?
I'd like to tune it from 6.0V (first LED) to 6.8V (fifth LED) in
increments of 0.2V.
It's not particularly important whether all preceding LEDs are lit, or
if just the Nth LED is lit, if this simplifies the circuit at all.
(For example, if voltage is 6.6V, corresponding to the 4th LED, it's
ok if only the 4th LED is lit, and not LEDs 1 through 4, if this makes
design easier.)
Thanks,
Michael
Bob Monsen
is on its charging.
increments of 0.2V.
design easier.)
Thanks,
Michael
If you have a voltage reference, you can easily scale voltages so that a
couple of quad comparators, along with 100k trimmers can be used to do
something like this.
Each stage is simple, it's an open collector comparator with the - input at
the range, the + input at the battery voltage, and the output connected to a
voltage source through a resistor and LED.
Vbatt 12V
6.8V .-------)------|-\ ___ LED |
| | | >--|___|-->|-----o
.-. o------|+/ 1k |
10k | | | |/| |
o-------)------|-\ ___ LED |
| | | >--|___|-->|-----o
.-. o------|+/ 1k |
10k | | | |/| |
| | | >--|___|-->|-----)
.-. o------|+/ 1k |
10k | | | |/| |
| | | >--|___|-->|-----o
.-. o------|+/ 1k |
10k | | | |/| |
6.0V '-------)------|-\ ___ LED |
| | >--|___|-->|-----'
'------|+/ 1k
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
You'll need to figure out how to get 6V, 6.8V, and 12V. You can use LM324s
instead of comparators, and use the extra three opamps to buffer voltage
dividers. If you have a 12V reference, like an LM7812, that would make this
easier.
Regards,
Bob Monsen
Phil Allison
is on its charging.
** So YOU still refuse to use the proper charge method.
Constant voltage @ 13.8 volts.
Then the current drops over the charge cycle.
........ Phil
....... Phil
13.8 volts into a 6V SLA... ha ha ha. You're a hoot.
Actually I set my LM317T to 6.75V, and I just want to know how long it
will take for the battery to float up to that.
Michael
E
Eeyore
Obviously 6.9V for a 6V battery.
Phil is right that a simple voltmeter is not a good indicator of the level of
charge, not least because the terminal voltage will rise whilst being charged
by varying degrees.
Graham
Yeah I know, I was just giving him a hard time. ;-)
by varying degrees.
Graham
Good point. I did notice that the battery would go up from its
original voltage to the charge voltage within a couple of minutes.
So if I've got a 10 A-h battery, and it charges at float at 500 mA, it
should charge for 20 hours at float to receive a full charge?
Michael
E
Eeyore
More like 30 hours actually since the process isn't 100% efficient. Also, the
charge rate will taper off with time.
Graham
E
Eeyore
John said:
The proper way to charge a sealed lead-acid battery is to limit the
initial charge current to that value specified by the manufacturer
while monitoring the voltage across the battery. Once the battery
voltage has risen to to the value specified by the manufacturer, then
that voltage should be maintained until the charging current drops to
the value specified by the manufacturer. Then, depending on whether
the battery will be used in cyclic or float mode, one of two actions
should be taken.
Here, From:
http://www.power-sonic.com/site/doc/prod/73.pdf
For a 12AH SLA:
Charging
Cycle Applications: Limit initial current to 3.6A. Charge until
battery voltage (under charge) reaches 7.20 to 7.35 volts at 68°F
(20°C).
Hold at 7.20 to 7.35 volts until current drops to under 120mA. Battery
is fully charged under these conditions, and charger should be
disconnected or switched to “float” voltage.
“Float” or “Stand-By” Service: Hold battery across constant voltage
source of 6.75 to 6.90 volts continuously. When held at this voltage,
the battery will seek its own current level and maintain itself in a
fully charged condition.
I completely concur.
In this instance the OP could perhaps organise a suitable current limit around his
regulator.
Graham
should be taken.
Here, From:
For a 12AH SLA:
Charging
(20°C).
disconnected or switched to "float" voltage.
"Float" or "Stand-By" Service: Hold battery across constant voltage
Thanks a bunch.
6.75V not etched in stone... 6.75 to 6.90 seems more reasonable.
Michael
