No need, replace the faulty discrete component.
If you must for some reason, make your own, then you must first determine how the LEDs are arranged in a series and/or parallel arrangement, the target wattage, and then the voltage and current regulation to get there.
Is it really worth the work? Bluejets already mentioned this. I think it is very unlikely worth the bother. Building your own PSU for this is likely to cost more than an entire replacement tube, without counting the value of your time, unless as mentioned already, you instead just find and replace the failed component and hopefully determine why it failed and do an upgrade to increase the lifespan of it.
From the insufficient info you have provided, merely stating "blow up", it might not even be the driver that is at fault, could be a PCB crack or if all LEDs are in series and none light up, a solder joint or LED bond wire fault.
You have not done the necessary work to better describe this circuit.
