I have built a control panel to turn on and off pumps, open and close valves and measure water levels in various tanks. I'm using an arduino Mega, relay boards and float switches to do this but now want to add some bling to the panel itself.... The panel is displayed graphically with a diagram of valves, piping and tanks and tank level gauges using red, yellow and green leds. What I want to do is place green leds every 1 inch on each line representing the pipe and when the valve for that pipe is open and water is flowing, I want to show the leds traveling or chasing each other down the pipe on the panel. How can I get this to work? Keep it simple please..... I have multiple pipes with different quantities of leds on each... More than one pipe can be flowing at a time.
Is what I have in mind not worth the effort!!! Should I settle for solid green or solid red........
