I am a jeweler who knows nothing about electronics.I was refered to
this site for help. I want to do jewelry with a LED component inside
which will show through various transparent stones , I would like it
to be a simple off- on with a steady light also to run off a watch
battery. I assume this is fairly simple but have no idea about the
electronics can anyone here point me in the right direction? thanks
Dave Owen
Traditionally LEDs have been driven from a fixed voltage source with a
current limiting resistor in series, this is important as LEDs have a fixed
forward voltage drop which should not be exceeded (between 1.75V & 2.2V for
red, green or yellow and about 3.4V for blue or white), this obviously means
a single 1.5V button cell will not do, the voltage source needs to be
sufficiently higher than the LED forward voltage that some voltage can be
dropped across the resistor to produce (Vs-Vled)/R=I which could be in the
range 2 to 20mA depending on the rated specification of the LED.
It is however increasingly becoming common practice to use a transistor or
chip voltage converters to drive a LED from a single cell, some types pulse
drive the LED so it can be driven harder for correspondingly narrow pulses -
persistence of vision gives the illusion of higher light output for a given
battery drain.
A couple of months ago Elektor Electronics magazine published an article on
a single-cell LED driver chip, accompanied by a free cover mount ready built
PCB, google for Elektor and see if the back issue is still available. The
chip is not much bigger than a pin head and only needs a couple of small
components added to make an LED driver not much bigger than the button cell.
