I would like to put 24 150mA smd LEDs in a space approximately 1.5 x 3". The LEDs I have picked out have a die heatsink that I believe needs to be thermally linked to a heat dissipating material.
I have been searching for an easy way to do this (something to put behind the LED, on the board), but I haven't found much for applications this small.
Does anyone have any suggestions on what to use? Does there exist some sort of bracket somewhere that I could easily use? Should I instead look into having a place like 4pcb.com build a circuit board for me instead? Can places like 4pcb.com build heat sinks into circuit boards?
These are the LED's:
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=219044159&uq=636225868333308885
http://www.cree.com/~/media/Files/Cree/LED Components and Modules/XLamp/Data and Binning/XLampML_BL.pdf
Thanks in advance!
Thanks in advance!
