Hi all!
I'm having a bit of an issue with a system I am trying to implement, I am using a DMX controller which I have used many times before with ribbon led strips but this time I need to use individual "star board" mounted red, green, blue and white LEDs. So my PSU has a 21.6v output and max 1.2A at 24V (it is variable but will only turn down to 21.6v) and I have strings in series of x6 of each colour connected to the output of the DMX controller.
The problem is that the green, blue & white led all have a current of 280mA and voltage at 3.0 - 3.4V but the red has a voltage range if 2.0 - 2.6V. I connected a 22ohm 2W resistor to the string and it gets VERY hot, I have also connected x2 22ohm resistors in series and although not as hot it is still unbearable to the touch, can you advise me what would be best?
I working it out I think I need a 39ohm 3W resistor in series with the string of 6 reds, I haven't got any to hand but is there a better solution before I take my hard earned money and turn it into another small space heater!
Malc
Malc
