I'm thinking of installing some led light strips to my car and have two twelve inch subs running at 500w each off of one amp. I have ran 0 gauge through the my car to the boot to a distribution block with multiple outputs. I also have a fuse coming off the battery for the 0 gauge and its 250amp fuse. I am curious to know if I can run power to my led light strips from the distribution block with an in line fuse aswell and then connect my negative to the negative terminal on the amp which has 4 gauge coming out being grounded to the car body. Also would running about 5 meters worth of leds around the car being cut and wired with what gauge to cause the least heat and least voltage drop be okay I don't really know. I wanna know if that's possible and whether or not it will be bad for the amp or the leds. Thanks in advance
Platforms
Content
