Ryan
I'm designing a bicycle light as the darkness is becoming longer and
longer this time of year.
I have selected the Luxeon III LEDs as they have good power in a small
package. I plan to use 3 of these LEDs in a single housing with the
Fraen trilens. Each LED will have its own power supply. These
require 4.5V at 700mA.
So my question is regarding the power supply. The battery is a NiMH
10.8V pack. I would like a constant current switch mode supply and
the maximum efficiency possible. It would be desired, but not
required, to run at lower than 700mA.
My thoughts are to implement a hysteretic synchronous buck converter
in a Cypress PSoC. I would use one of those fancy IRF FETKY devices
with both N MOSFETs and diode in one package. I'd need a charge pump
for the high side MOSFET too.
Would a hysteretic synchronous converter provide the best efficiency?
Is there a better topology? Has anyone done such a thing in the PSoC?
Any input is appreciated.
Thanks,
Ryan
Thanks,
Ryan
